2002 Ford Ranger
71,000 MILES • 6 CYL • 2WD • AUTOMATIC
PMAN8765
  • 7 POSTS
Latley my truck, after going about 15 minutes and sometimes after I idle my truck we just die on me. It happened first when i was sittin at a red light and it turned green, i hit the gas and nothing happened. So it tuck me about 9 times and i finally got it cranked. So about 5 minutes later i was pulling in school and it died on me again, That time it only took about 2 times to crank it. So we took it to the shop and they replaced the belts on it. So about 5 days later I was driving it, i had been idleing for about 2 minutes and i started to go again and as i started to slow down it died again. some people say the iac and some say it might be a sensor. so what do yall think
Feb 4, 2009 at 11:51 AM
BMRFIXIT
  • 19,053 POSTS
I would suspect the IAC valve too
check list :
check for vacuum leaks and intake manifold
check fuel pressure
Feb 4, 2009 at 12:33 PM
PMAN8765
  • 7 POSTS
Could it be the catytlac converter
Feb 5, 2009 at 8:22 AM
BMRFIXIT
  • 19,053 POSTS
Not likely
do u have any codes check and scan for codes
Feb 5, 2009 at 9:08 AM
PMAN8765
  • 7 POSTS
no i dont, we took it to the ford place but we hadnt heard back form them, it also makes a whistling noise under the hood and a noise that sounds like a bird or a mouse , which sounds like it is coming from the back, the guy at the ford place mentioned a cam, if that means anything. o by the way thanks for all the help
Feb 5, 2009 at 11:19 AM
BMRFIXIT
  • 19,053 POSTS
Whistling noise !?
sounds to me as a vacuum leak
let me know what they come back with
good luck
Feb 5, 2009 at 9:25 PM
PMAN8765
  • 7 POSTS
we got the truck back they didnt do anything they cant figure it out they ran dianogtics test, nothing poped up. we went and bought an iac and is getting put in tomorrow
Feb 6, 2009 at 10:01 AM
PMAN8765
  • 7 POSTS
could it be the cam sensor
Feb 7, 2009 at 12:20 PM
BMRFIXIT
  • 19,053 POSTS
A faulty cam sensor will give you a check engine light
I hate to see you replacing good parts
no intake gasket leak !
test fuel pressure !!
Feb 7, 2009 at 1:27 PM
