2001 Ford Ranger what is on the fuel rail?
2001 FORD RANGER
PERRYTIME
Engine Performance problem
2001 Ford Ranger Two Wheel Drive Automatic 134000 miles
It appears to me the fuel pressure is regulated in the tank, I see no return line on fuel rail. there are 2 lines between tank and fuel filter. What looks like a traditional fuel pressure regulator is on the fuel rail, between 2 injectdors, it has a vacuum line to it. Fuel pressure was 65 with and without vacuum line connected. What is function of this device? The device does hold a vacuum, so diaphram is good.
May 18, 2010 at 3:33 PM
BLUELIGHTNIN6
  • 16,542 POSTS
does it look similar to pic below? if so that's your fuel injector pressure damper..
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_2187.jpg
May 18, 2010 at 3:46 PM
PERRYTIME
Sounds like nothing I need to worry about. I just wanted to be sure its normal for fuel pressure to be constant with device unplugged.
thanks
May 18, 2010 at 3:50 PM
