2001 Ford Ranger steering/suspension squeaking
100,080 MILES • 6 CYL • 4WD • MANUAL
RICK56
I have a 2001 ranger 4x4 and since it turned 100000 miles, the front end squeaks when i turn the wheels and when i go over bumps at low speeds. It seems to be coming from the right wheel assembly but I really cant identify the problem. I've sprayed every bushing or moving parts with lubrication and still the squeaking continues. Would this possibly be something in the steering like a tie rod going bad, ball joint, or simply a shock going bad?? Nothing seems stiff in the steering nor does it ride any different. Thanks for your time.
Apr 11, 2008 at 1:14 PM
BMRFIXIT
  • 19,053 POSTS
the most common is Ball joints
also check the stabilizer links
Apr 11, 2008 at 1:46 PM
