2001 Ford Ranger replaced turn signal bulb, still doesn't w
130,000 MILES • 4 CYL • 4WD • AUTOMATIC
FLSMIKE
My turn signal indicator started hyper flashing the other day and I discovered the rear passenger side signal was not working. I replaced the bulb with the item number recommended in the manual but it still fails to work. I checked the fuse for the turn signals and it appeared to be OK. any suggestions/ideas on what to look for next? thanks!
Mar 17, 2009 at 3:39 AM
AARON8200
I have the same problem in my 2000 Ranger. The driver side front turn signal light doesn't work. The rear flashes fast. I changed the blub and then the flasher and it still doesn't work.
Mar 19, 2009 at 9:06 AM
