2001 Ford Ranger Engine will not start
85,000 MILES • 4 CYL • 2WD • MANUAL
BLOUCKS
Truck runs fine. Drive it any amount of time, but sometimes when you shut it off, it will not start. Leave it sit for an hour to three hours and it will start up and run fine. This does not happen every time. Had it to several mechanics, can not get it to do this.
Last time had $1000 tune up, said it was fixed, three weeks later same thing.Had plugs,wires,filters replaced,supposely checked fuel pressure. Have been told it could be a vacuum created in the tank vent causing no fuel, or could be a fuel pump going bad when it is hot, could be the Emergency fuel cut-off valve(one in case of rear ending) causing the problem. Was told by mechanic there was NO Error Codes. Anytime I drive it I have to be prepared to wait up to three hours in case it will not start.
Can not figure out why a mechanic can not fix it. Know that if it is running, makes it hard to find. But if you know the problem, then they should because they are looking at the truck. Any suggestions would bee greatly helpful.
If I take the fuel tank cap off and put it back on, truck will start immediately
Feb 4, 2010 at 9:04 AM
RACEFAN966
  • 5,029 POSTS
Ok this has to be checked out when it won't start. When it is running it will check out fine and no problems will be found. Now next time is won't start I need you to check to see if there is spark. If there is spark then check for fuel pressure. Keep in mind it has to not be starting to find the problem.
Feb 5, 2010 at 1:39 AM
