HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Ford
Ranger
Engine
Symptoms
Stall While Driving
2001 Ford Ranger dead on side of the road.
POLUTED_MYND
MEMBER
2001 FORD RANGER
6 CYL
2WD
AUTOMATIC
165,000 MILES
The truck died on me while driving no throtle responce wont stay running and wont stay at level idle any suggestions?
Monday, October 12th, 2009 AT 8:09 PM
OBXAUTOMEDIC
MECHANIC
Could be few things.
TPS (Throttle Position Sensor)
IAC (Idle Air Control) Valve
MAF (Mass Air Flow) Sensor
Weak Fuel Pump
Weak or Bad Fuel Pressure Regulator.
If engine light is on will help greatly if you can get codes and post them.
SPONSORED LINKS
Monday, October 12th, 2009 AT 8:27 PM
Please
login
or
register
to post a reply.
Related Engine Stall While Driving Content
2001 Ford Ranger Engine Shut Off While Sitting At...
Yesterday I Was Sitting At A Light And My Engine Shut Off. The Check Engine Light Did Come On. I Tried To Restart The Engine But The...
Asked by
pcouch
1 ANSWER
2001
FORD RANGER
VIDEO
How to Read Codes
Instructional repair video
GUIDE
Engine Stalls While Driving
An engine that stalls while driving and then starts back up again, either immediately or after a short time is different from an engine that just wont start or if the...
2001 Ford Ranger Engine Cuts Out On Hard Acceleration
This Is A 2001 Ranger Xlt 3.0l 2wd Auto With 120,000 Miles On Medium To Hard Acceleratoin Or Going Up A Grade Accelerating, The...
Asked by
frediop
1 ANSWER
2001
FORD RANGER
Engine Stalls
Recently My Ranger Would Not Idle After I Started It. Fires Up, Then Dies. If I Held The Gas Pedal Down It Would Run Rough, But Then Die...
Asked by
bluzharp
2001
FORD RANGER
2001 Ford Ranger Bucking During Snowy Weather
The Truck Bucks Or Jerks When It Is Snowing. It Even Happens On A Nice Day When I Get Behind A Semi With A Mound Of Snow On Top Of The...
Asked by
redingt3
2001
FORD RANGER
2001 Ranger Stalls
My Ford Ranger 3.0l On Some ( Not All) Cold Mornings Will Start And Imediately Stall If I Do Not Give It A Little Gas. After A Short Time...
Asked by
Thorgar24
2001
FORD RANGER
VIEW MORE
SPONSORED LINKS
Code Read Retrieval/Clear Mercedes Benz
How to Read Codes
Is it Safe to Drive Check Engine Light?
Online car repair manuals
