2001 Ford Ranger code p0305
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
DUCKNEST1
changed plugs but still has a miss and still receiving code P0305 what shoud i look for now
Feb 24, 2009 at 3:23 AM
RANGERDANGER17
  • 224 POSTS
pull off all the wires and look down into them if they are not bright shiny bronze color the miss is right there
then pull off the wire where they plug into the coil packs the metal contact points should be shiny if not they are bad
black burnt contact pionts cracked coil packs are going to cause that miss
Feb 24, 2009 at 8:55 AM
