Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
Ranger
Trouble Codes
P Codes (Powertrain)
P0300 - P0399
P0305
2001 Ford Ranger code p0305
2001 FORD RANGER
70,000 MILES • 6 CYL • 2WD • AUTOMATIC
DUCKNEST1
MEMBER
1 POST
changed plugs but still has a miss and still receiving code P0305 what shoud i look for now
Feb 24, 2009 at 3:23 AM
RANGERDANGER17
MEMBER
pull off all the wires and look down into them if they are not bright shiny bronze color the miss is right there
then pull off the wire where they plug into the coil packs the metal contact points should be shiny if not they are bad
black burnt contact pionts cracked coil packs are going to cause that miss
Feb 24, 2009 at 8:55 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
