2001 Ford Ranger Clutch won't engage into gear
78,000 MILES • 6 CYL • 2WD • MANUAL
CLOP52
It has been happening on and off for the past 6 months. My clutch would not allow me to engage into gear, especially when is cold outside. Usually I just pump the clutch and that fixes it. This morning, although it wasn't as cold as it has been, the clutch started going well, from first to second and then when i tried to go into third it did it again. It felt like it had a little backlash and it stopped allowing me to engage into gear. I waited for a minute and even added some DOT-3 fluid, but did not work.
Mar 1, 2010 at 7:17 AM
  • 110,248 POSTS
Does the trans shift normal with the engine off?
Mar 1, 2010 at 7:45 AM
CLOP52
I don't know yet. I am not home, but could you tell me what to do if it did and if it didn't?
Mar 1, 2010 at 8:15 AM
CLOP52
I did engage while the engine was shut off. I was able to drive it back to my house in first gear. It would not change gears though. When I put it in nuetral to try and shift up to second it stuck again and I had to shut the engine off, shifted into first, start the car and then go. Do you think the master cylinder could be the problem?
Mar 1, 2010 at 12:09 PM
CLOP52
By the way, while the engine was off the trans shifted into every gear like normal.
Mar 1, 2010 at 12:11 PM
