2001 Ford Ranger Clutch
14,000 MILES • 6 CYL • 4WD • MANUAL
BACARDI4ME
Clutch not working at all, when I press down there is nothing just right to the floor.
Replaced the Slave Cylinder and still nothing then i bought a clutch kit and replaced the clutch and pressure plate, still nothing.
I am at a loss as to what to do next.
Please email with any suggestions I need to get this truck back on the road ASAP.
Sep 18, 2008 at 1:10 AM
DOCFIXIT
  • 18,828 POSTS
Master cylinder good? Did you disconnect line at trans depress interanl mechanism with small screw driver. Then depress pedal while opening valve. Then reconnect line pump pedal 5 times open bleeder repeat 3 times. If master is good you should have pedal.
Sep 18, 2008 at 1:28 AM
