2001 Ford Ranger blown fuse
100,080 MILES • 6 CYL • 2WD • AUTOMATIC
TMOEALL
my a/c and air bag and overdrive fuse keeps blowing?
Feb 11, 2008 at 1:00 PM
FISHERMAN
  • 937 POSTS
[quote:37e3112dcc="tmoeall"]Electrical problem
2001 Ford Ranger 6 cyl Two Wheel Drive Automatic 100080 miles
my a/c and air bag and overdrive fuse keeps blowing?[/quote:37e3112dcc]
start disconecting the a/c clutch and see if the fuse blows again could be a grounded wire, also follow the wires and be sure that are in good shape and see if they are well insulated.
let us know!
Feb 11, 2008 at 2:00 PM
FLEXY5
  • 512 POSTS
Is it the same fuse for all three components? If so, check for a chaffing wire in the steering column. It also may be what is refered to as the "clock spring." It is a spool of flat wires that allows the connection to the driver's airbag and steering wheel controls without being broken when you turn. Check the steering column first, though, and post back. We'll go from there.
Feb 11, 2008 at 2:02 PM
