2001 Ford Ranger Add on Transmission Fluid Cooler
13,400 MILES • 6 CYL • 2WD • AUTOMATIC
MLABUDA
I need to repair/replace the add on trans. fluid cooler. This cooler was there when I bought the truck. Can I temporarily just combine the 2 lines going to the cooler (1 line then goes to standard radiator) in order to get to the parts store and do I even need this add-on at all ?
Nov 13, 2009 at 2:33 AM
DOCFIXIT
  • 18,828 POSTS
Hi You do not need it added likely for towing. So routing it to radiator as stock is fine. Would recomend steel line though.
Thanks for donate
Nov 13, 2009 at 7:45 AM
