2001 Ford Ranger
82,000 MILES • 6 CYL • 2WD • MANUAL
SPARKS220
01 Ranger 82000 miles manual trans when I first start it up in the mornings or if it has been sitting for a few hours there is a grinding/knocking/rattling noise coming from either the bottom of the motor or transmission. After running for a couple of minutes the noise does go away. (its not loud but somthing is rattling) There is also a deep throated knocking sound when I pull a hill but it's not there all the time. I see they are putting auto trans fluid in instead of gear oil is the rattling possiably due to the thinner oil and it takes longer to lub the gears.
Jun 3, 2010 at 7:03 AM
  • 110,251 POSTS
The use of ATF in a manual transmission is actually to get luberication to everything quicker. However, based on your description, it doesn't sound like a transmission problem. If you hear a knocking in the AM and when pulling steep hills, it almost sounds like a main or rod bearing in the engine. HAs the oil been changed on a regular basis?
Jun 3, 2010 at 3:29 PM
