2001 Ford Ranger
GSXRJIMMY
Electrical problem
2001 Ford Ranger 6 cyl Four Wheel Drive Automatic
my trucks not giong into 4 wheel drive. the fuses seem to be intact. when I turn the key to start the truck, the instrument panel lights up but the 4x4 indicator lights do not come on
Jan 10, 2010 at 5:57 AM
  • 110,251 POSTS
I need you to check if there is power to the 4wd actuator on the transfer case. Make sure the plug is clean and tight, free of corrosion.
Let me know what you find.
Jan 12, 2010 at 12:52 AM
