2001 Ford Ranger
KERMIT22
Interior problem
2001 Ford Ranger 6 cyl Two Wheel Drive Automatic
How do you remove the cover to gain access to the gauges?
Mar 15, 2009 at 12:31 AM
MERLIN2021
  • 17,250 POSTS
INSTRUMENT CLUSTER Removal & Installation 1. Disconnect negative battery cable. Remove 2 screws from center instrument panel finish panel and pull out center instrument panel finish panel. Remove radio. Disconnect electrical harness connectors. Remove hood latch release handle and cable from instrument panel steering column cover. 2. Remove 2 screws and instrument panel steering column cover. Remove 4 screws and instrument panel steering column opening cover reinforcement. Position column gear shift lever aside (if equipped). Remove 3 screws and pull out cluster finish panel. Disconnect electrical harness connectors and remove cluster finish panel. 3. Remove 4 instrument cluster screws. Pull out instrument cluster and remove transmission range indicator (if equipped with automatic transmission). Disconnect electrical harness connectors and remove instrument cluster. To install, reverse removal procedure. © 2008 Mitchell Repair Information Co., LLC. CAUTION: Instrument cluster light bulbs are pressurized and may shatter if improperly handled. Wear eye protection when replacing instrument cluster light bulbs. Page 1 of 1 INSTRUMENT PANELS - ANALOG -2001 Ford Ranger 3/15/2009 http://www.ondemand5.com/mric/common/asp/printart.aspx
Mar 15, 2009 at 1:36 AM
