2001 Ford Ranger
102,000 MILES • 6 CYL • 2WD • AUTOMATIC
MRFORDRANGER
2001 Ford Ranger, had slight ticking noise @startup but went away within a couple minutes. The other day the Oil was low when i checked it so i added oil. (no noise at oil add) Afterwards, oil pressure went errartic at gauge. Had oil changed, new filter, and oil sending unit replaced. Now, no oil pressure indicated on gauge. Engine clicks all the time. (no knocking, just clicking). Help
Nov 21, 2008 at 12:26 AM
BMRFIXIT
  • 19,053 POSTS
From the sound of it you are running with low oil pressure
need to have it check ed
have the oil pump checked and pressure tested
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Nov 21, 2008 at 10:29 PM
