2001 Ford Ranger
ASHMANIA123
Electrical problem
2001 Ford Ranger 6 cyl Two Wheel Drive Manual
turn signals, hazard lights, reverse lights, and brake lights stopped working. headlights and parking lights do work. please help.
Jul 5, 2008 at 9:01 AM
BLACKOP555
  • 10,386 POSTS
first thing i would check would be the turn signal switch since it is all integrated.
does the thrid brake light work if equipped? the one above the window.
get a different switch from the junkyard as the new ones are steep in price.
Jul 5, 2008 at 9:32 AM
ASHMANIA123
yes there is a third brake light but it doesnt work either. where is the turn signal switch?
Jul 5, 2008 at 10:55 AM
BLACKOP555
  • 10,386 POSTS
its what you use to turn on the turn signals...
check the fuses and relays also
would even check for a damaged wiring harness due to the no third brake light.
Jul 6, 2008 at 10:26 AM
