2000 Ford Ranger Will not back up when cold
79,000 MILES • 6 CYL • 4WD • AUTOMATIC
HMAC
The Ranger runs fine forward but when cold the truck will not back up. Once the truck is warm, it backs up fine. I checked the transmission fluid and it it full. I had a mechanic check it and he said the pressure was a little low. Does this mean there's no alternative but to replace or rebuild?
Dec 9, 2009 at 12:18 AM
RACEFAN966
  • 5,029 POSTS
Have you done a trans service yet? If not I would do a service. This is where you remove the trans pan and replace the filter inside and fill back up with new fluid. The proper fluid is dextron/mercon.
Dec 9, 2009 at 2:31 AM
