2000 Ford Ranger vss-error message
136,000 MILES • 6 CYL • 2WD • AUTOMATIC
DOGGONE
  • 6 POSTS
I submitted my qestion before. Check engine light on, error message ,veh. speed sensor, Tranny shift hard, overdrive light flashing, wipers won't work, chgd alternator, changed rear wheel speed sensor in rear end,(as advised in previous anwser), no change. Has anyone run into this problem and can help?
Jan 23, 2009 at 2:17 AM
DOCFIXIT
  • 18,828 POSTS
Hi
Did you use a scanner to get code? if so what was code in P0xxx format.
Let me know
Also is it a 3.0L V6
Jan 23, 2009 at 6:33 AM
DOGGONE
  • 6 POSTS
Problem-speedometer not wkg-overdrive light flashing-transmission shifting rough.OBDII reading PO500. changed ABS/VSS in rear end. OHMS reading is 1.76 //OHMS-on the VSS sensor in the rear end. 4.6 volt from the wire connecting to it. According to what I have researched the Ohms reading should be between 0.8 to 1.4. Needless to say I am still have the same problems listed above even after resetting the computer and disconnecting the battery. Do you have any suggestions? Thanks
Jan 27, 2009 at 5:37 AM
DOCFIXIT
  • 18,828 POSTS
Your code is for problem with wiring from PCM to VSS.
Either open or short if it passes both tests then PCM is fault. It is atest requiring a diagnostic scanner. Am trying to find another way for you to test. Do you have wiring diagrams? a digital volt Ohm Meter?
Try to have something for you soon.
Jan 27, 2009 at 8:34 AM
DOGGONE
  • 6 POSTS
I don't have a wiring diagram. Yes, I have a digital ohms meter
Jan 28, 2009 at 1:00 PM
DOCFIXIT
  • 18,828 POSTS
O.K. going to test VSs and RABS to eliminate or confirm problem.Ignition on engine off locate RABS DTC connector behind pass. side kick panel.Connector has black/orange wire one side and red other. Pull connector apart take jumper wire from black/orange to ground. Yellow ABS warning light will flash these will be fault codes.
Short flash and long flash so it goes short short long = 3, short short short short long = 5.
If you get 16 system is good.
Let me know
Also locate PCM right rear engine compartment through firewall.
Jan 29, 2009 at 12:52 AM
