2000 Ford Ranger vehicle speed sensor?
IAN_NYE
  • 2000 FORD RANGER
  • 6 CYL
  • 74,000 MILES
I own a 2000 ford ranger with the 3.0L v6. Recently my mother drove to the airport (about an hour and a half drive for us) and got cut off by some woman in front of her and had to slam on the brakes. This resulted in the ABS light on the dash to come on. Well on the way home the truck started having trouble accelerating and shifting gears. When I went out to check things out. The check engine light and and the ABS light were both on. I took it for a test drive and found that the speedometer was not working well and the transmission was shifting into any and all gears for no reason. Needless to say I borrowed the diagnostic machine from my work and (i work at a quick lube) it read the code from "vehicle speed sensor". I pressed the reset button and have been afraid to test drive for fear of causing permanent damage to the transmission. I was also told that this sensor doubles as an ABS sensor and that was the reason for the ABS light. Im just curious if resetting the light will be enough or if I need to replace the sensor itself?
Saturday, January 31st, 2009 AT 4:02 PM
BMRFIXIT
  • 19,053 POSTS
Reset the code s will not fix the problem if it is a sensor or so
try and reset the codes but 1st record down the codes
drive it around if light come back on
check it again
rear differential has a sensor on it
it serve as ABS and speed sensor
let me know what do u have for codes
Sunday, February 1st, 2009 AT 4:07 PM
SHELLEY1014
My truck is doing same thing, oh my gosh please ian nye tell me the final results. Thank you I checked my sensor isnt it?
Sunday, February 20th, 2011 AT 9:43 PM
