2000 Ford Ranger Top end noise
96,460 MILES • 6 CYL • 4WD • AUTOMATIC
MNTNEER
I have replaced the heads, valves, and lifters, but I still have clatter, sounds like rockers. I have not replaced the pushrods or rocker arms. Please help.
Mar 4, 2008 at 10:39 AM
FLEXY5
  • 512 POSTS
Were they remanufactured heads or new heads. If the heads were remanufactured, the difference of the thickness that has beed milled off is causing noise. The rods are too long now and the valves are opening too far. I can't remember if it has adjuster screws on the rockers. If so, adjust the rockers. If not, they make a shim kit for the rockers. If you have any other questions feel free to ask.
Mar 4, 2008 at 1:55 PM
