2000 Ford Ranger Tempurature gauge
DA10679
  • 2000 FORD RANGER
  • 6 CYL
  • 4WD
  • 96,000 MILES
The engine temp. Gauge is maxed out, even when the engine is cold. Is the problem with the thermostat, the gauge or some kind of sensor?
Wednesday, September 3rd, 2008 AT 8:42 PM
RENAUDTN
  • 636 POSTS
If the gauge reads 'hot' even when engine is cold, I doubt it's your thermostat.
I'd check the sending unit, the gauge itself, and the wiring in between; depending on the type of gauge your car is using, you could have a wire partially grounded somewhere, or an open in the circuit.
Thursday, September 4th, 2008 AT 2:57 PM
