2000 Ford Ranger Starting problems
143,423 MILES • 4 CYL • 2WD • MANUAL
SPOOKY_1979
my first start up in the morning can take me up to five minutes once the truck is running everything is fine i can start it up normally the rest of the day ive replaced fuel filter,plugs&wires no improvment i was wondering about the fuel pressure regulator if that could be the problem and if so where is it located?
Oct 27, 2010 at 10:28 AM
  • 110,248 POSTS
The fuel pressure regulator is on the fuel rail. What you should do is check fuel pump pressure, drop off, and at the same time check the regulator. Here is a how to for checking them:
https://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Mar 2, 2021 at 3:45 AM
SPOOKY_1979
I dont have a fuel pressure gauge however I did remove the vacuum line while motor was running it stalled out and then picked up acceleration
  • 110,248 POSTS
That is because the pressure increased. Was there any evidence of fuel in the vacuum hose? As far as a gauge, most nationally recognized parts stores will lend them to you.
SPOOKY_1979
I got the gauge and ran the pressure test needle barely moved when i turned the key on bought and installed a new pump seems to have fixed the problem. Thank you for your time you was a big help
  • 110,248 POSTS
First, thanks for the positive feedback. It's appreciated. Second, I'm glad you got it fixed. I had a feeling that was the problem.
Take care of yourself and let us know if you have questions in the future.
Thanks again,
