2000 Ford Ranger Squeek in the front end
2000 FORD RANGER
CJANDJPSMOM
Noises problem
2000 Ford Ranger 6 cyl Four Wheel Drive Automatic
I have a 2000 Ford Ranger 4WD that makes a squeak and squeal when you turn the wheel. It is not locked into 4 wheel and sounds like the noise is either coming from the boot or the shock in the front driver's side. Any ideas what it might be?
Dec 28, 2009 at 7:44 AM
MERLIN2021
  • 17,250 POSTS
Iwould check the shock, and ball/tir rod ends. Did not see a mileage listed, but if it's a high milge truck, suspect worn front end parts.
Dec 28, 2009 at 7:56 AM
