2000 Ford Ranger solenoid starter connections
2000 FORD RANGER
165,000 MILES • 4 CYL • 2WD • MANUAL
SGRAIMBERT
  • 6 POSTS
hi,
I think that the solenoid starter connections ard completely worn out.
when the ignition key is turned, the solenoid energises but the engine does not turn
I would like to know if by adding a solid state relay and using the same solenoid,i can bypass the connections .
many thanks
May 17, 2010 at 7:36 AM
  • 110,244 POSTS
Is the solenoid on the starter or the inner fender on your vehicle?
May 18, 2010 at 3:42 AM
SGRAIMBERT
  • 6 POSTS
it is on the starter
May 18, 2010 at 6:41 AM
  • 110,244 POSTS
It actually sounds like a bad starter. If the solenoid energises but the starter doesn't turn, chances are it is bad. I recommend removing it and having it bench tested at a parts store.
Let me know what you find.
May 19, 2010 at 12:29 AM
SGRAIMBERT
  • 6 POSTS
my starter works when i jumped both terminals of the solenoid.This is why I asked you if I can use solid state relay instead.
May 20, 2010 at 12:22 AM
  • 110,244 POSTS
It may work, but I would recommend staying with direct fit parts. When you change things, there always seems to be a problem.
May 20, 2010 at 12:26 AM
SGRAIMBERT
  • 6 POSTS
Silly Question
Do you know what solid state relay is ?
May 20, 2010 at 3:25 AM
  • 110,244 POSTS
May 20, 2010 at 4:25 AM
SGRAIMBERT
  • 6 POSTS
why do say "it may work" then?
no break and make contacts,no arcing, just electronic switching.It should be good and last longer I guess.
May 20, 2010 at 4:50 AM
  • 110,244 POSTS
I am asked to recommend direct fit OEM type parts to avoid any problems. Will it work? I don't see why not. However, I can't make that recommendation to you incase there is a problem.
Try to think of the potential problems that could occur if we said good idea to every modification people wanted to make. Please understand, most of the people that ask questions know very little about cars. We even had to add "how to open your hood" directions. When they start trying to modify factory parts, things can go bad really fast.
However, there are many people that are very bright and good mechanics that ask for help too. The problem is, I can't tell who is who via the net.
May 20, 2010 at 5:04 AM
SGRAIMBERT
  • 6 POSTS
ok.
I'm sorry, I didn't know if you had to be withinn certain parameters.
Thanks anyway.
May 20, 2010 at 5:42 AM
  • 110,244 POSTS
Not a problem. If you ever have questions in the future that you need help with (OEM type) I have access to a lot of info and would be glad to help.
May 20, 2010 at 6:44 AM
