2000 Ford Ranger Replacing transmission after replacing sla
163,500 MILES • 6 CYL • 2WD • MANUAL
RGUY46
After removing the transmission to replace the clutch slave cylinder, I am unable to get the transmission close enough to the bell housing to bolt it back up. It seems like the slave cylinder is against the pressure plate and keeping it about 3/4 inch from the bell housing. Does the tranny have to be forced forward to bolt it up?
Aug 11, 2010 at 4:41 AM
DOCFIXIT
  • 18,828 POSTS
Hi Trans input shaft not hitting pilot bearing. trans and engine MUST be parallel, trans jack should not hold trans in bind need to be able to pick up tailshaft to manuver into pilot bearing.
Hope this helps
Thanks for donate
Did you replace clutch and pressure plate also?
Aug 11, 2010 at 5:20 AM
RGUY46
Yes, I put the whole new clutch kit in new. Used an alignment tool for the clutch. I will try again. Thanks for the reply.
Aug 11, 2010 at 5:25 AM
RGUY46
I will probably be back with you to find out how to bleed the cylinder the RIGHT way.
Aug 11, 2010 at 5:28 AM
DOCFIXIT
  • 18,828 POSTS
O.K. good luck takes alot of wiggling if have an assistent one on tailshaft other on bell housing should slide in and mate
Aug 11, 2010 at 5:29 AM
