2000 Ford Ranger Rear Differential Leak
MYFORDRANGER
Other Category problem
2000 Ford Ranger Two Wheel Drive Automatic 108000 miles
I have a leak from the driveshaft end og the differntial that only occurs after I have driven the truck and parked it for a period of time. I noticed when checking the fluid level that a pressure release sound hissed from the drain plug when removed. I suspect the differntial pressure vent is blocked but I cannot locate the vent. Where is it located?
Jan 16, 2008 at 6:50 AM
98RANGERXLT
  • 301 POSTS
It does not have a pressure release i dont think, your seal maybe bad in the driveshaft.
Jan 16, 2008 at 8:02 AM
