2000 Ford Ranger Packet Scanner
128,000 MILES • 6 CYL • 4WD • AUTOMATIC
MIKE INGER
My truck started misfiring and bucking at highway speeds, and the check engine light came-on.
Purchased an ACTRON 9125 pocket code scanner to read the trouble code, however when plugged into the trucks test port, the sanner does nothing.
The scanner works as I tried it on a 2003 Mazada Tribute. Question, is it possible that the trucks misfire , and lack of communication in the test port are related ?
Mar 18, 2009 at 3:13 AM
DAVE H
  • 13,383 POSTS
check fuse #17 in central junction/fuse box behind left side of dash .. (cigarette lighter fuse) this sends hot feed to DLC(data link connector)
Mar 18, 2009 at 3:41 AM
