2000 Ford Ranger No clutch pedal pressure
JOHN.PULLEY
Transmission problem
2000 Ford Ranger 4 cyl Two Wheel Drive Manual 78K miles
Added DOT3 fluid to level and clutch worked fine. The following day lost clutch pressure, there is no visible leak.
Feb 26, 2009 at 9:29 PM
DAVE H
  • 13,383 POSTS
Hello .. thanks for the donation .. much appreciated
Was the the reservoir empty or real low when you topped it up ! is it empty again now ! it is possible air has gotten into the sytem and needs bleeding off ? if the fluid reservoir is low or empty again now .. you must have a leak somewhere ? or it was real low and has now gotten air trapped ? let me know
The hydraulic clutch control system consists of the hydraulic master cylinder, slave cylinder, reservoir, clutch pedal position switch and connecting hydraulic lines. The clutch disc and pressure plate are single-disc type. The clutch release bearing or bearing arm is activated by hydraulic pressure. The clutch linkage or pedal position requires no adjustments.
Feb 26, 2009 at 10:49 PM
