2000 Ford Ranger new water pump' new idler pulles
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
BIIG BARRY
I HAVE A 2000 FORD RANGER 3.0 FLEX FUEL ENGINE ,PUT ON A NEW WATER PUMP JAN. 08 . AN ANOTHER ONE JULY 3 08, IT SQUEAKS ,IF YOU SPRAY WD-40 IT STOPS FOR ABOUT 5 MINS. THEN STARTS AGAIN WHATS CAUSING THIS
Jul 4, 2008 at 4:15 PM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:ec7c2d7405="biig barry"]Noises problem
2000 Ford Ranger 6 cyl Two Wheel Drive Automatic 125000 miles
I HAVE A 2000 FORD RANGER 3.0 FLEX FUEL ENGINE ,PUT ON A NEW WATER PUMP JAN. 08 . AN ANOTHER ONE JULY 3 08, IT SQUEAKS ,IF YOU SPRAY WD-40 IT STOPS FOR ABOUT 5 MINS. THEN STARTS AGAIN WHATS CAUSING THIS[/quote:ec7c2d7405]
Ok, are you sure its the w/p. when you sprayed with wd40 was the vehicle running? if so before starting the vehicle spray the pump then start the vehicle if noise is still there turn vehicle off locate the Tensioner pulley or the Idler Pulley, just spray one of them and start the vehicle if noise stops replace pulley. repeat with other pulley if noise continues.
I noise still continues after that then spray belt if noise stops replace belt.
post findings here in forum
Jul 5, 2008 at 4:52 PM
