2000 Ford Ranger just wondering
LOUIISJGARDNER7809
2000 Ford Ranger Two Wheel Drive Automatic
everything work on it fine other the the front right door handle wont open from the outside only from the inside is there anyway to fix it do i just gotta get a new door
May 20, 2008 at 7:49 AM
MERLIN2021
  • 17,250 POSTS
Inside the door there are several thin steel rods, these connect the handles, to the locks, and catches...remove the trim look for the rod, put a new retaining clip on the rod and reinstall the loose end! P.S. use a trim removal tool or you may break the clip holders in the door! Get under and around the plastic clips and pop them out...
May 20, 2008 at 7:59 AM
