2000 Ford Ranger engine almost stalls
MTGRIFFIN
  • 2000 FORD RANGER
  • 6 CYL
  • 80,000 MILES
When sitting idle for a couple of minutes, the engine seems to either go into a very low idle to the point the engine almost stalls. It starts jumping around similar to as if it was missing. It started a couple of months ago and during this time some days are really bad and others I don’t experience it problem.
Replaced fuel pump, fuel filter and IAC the first time I brought it in shop about a month ago. The same shop has had it for four days this week and they have not been able to isolate the root cause of the problem.
Friday, October 9th, 2009 AT 3:03 PM
  • 109,885 POSTS
Has the check engine light come on? Have they tested the throttle position sensor? Vacuum leaks?
Wednesday, October 28th, 2009 AT 8:17 AM
MTGRIFFIN
The check engine light has never come on. I'm not sure if they have tested the throttle position sensor or for vacuum leaks.
Since my last post, I replaced the plugs and wires and still had the same problem.
The shop replaced both of the oxygen sensors and that seems make things a lot better. It is not running perfectly and although I have not experienced the same degree of the problem the engine does hint that there is still an underlining problem.
Now I have a new problem that started the day I turned it in the shop last time. About half of the time I try to start the truck, it cranks but does not start. I have to waiting a few minutes and try again.
Monday, November 2nd, 2009 AT 2:57 PM
  • 109,885 POSTS
For the original problem, I would recommend checking for vacuum leaks. As far as the new one, it sounds like it could be the electronic engine control (EEC) relay. When this happens, I need you to listen to see if you hear the fuel pump run for a second when you first turn on the key. Also, if possible, check to see if there is spark to the plugs. If you need directions, let me know.
Monday, November 2nd, 2009 AT 7:07 PM
