Do you pull the driveshaft?
CEDMIS
Do you pull the driveshaft on a 2000 ford ranger beginning from the front or the rear?
Oct 26, 2009 at 8:40 AM
SQM
  • 6,383 POSTS
The drive shaft can be removed starting at the rear axle pinion flange.
Here is a helpful guide:
https://www.2carpros.com/articles/how-to-remove-a-drive-shaft
I have attached the replacement procedure below.
Dec 6, 2021 at 9:58 AM
