2000 Ford Ranger dome light
2000 FORD RANGER
108,000 MILES • 4 CYL • 2WD • MANUAL
MELVIN HARRIS
i have a 2000 Ford Ranger and sometime the door ajar light comes on and sometime it does not. When the door ajar light comes on the dome light stays on all the time.You can poen and shut the door and sometime the light will go off like it should and sometime it will not. Can you tell me what the problem is? Is there a switch behind the door panel?
Jul 16, 2008 at 10:53 PM
BMRFIXIT
  • 19,053 POSTS
most likely driver door switch.
have the system scan, will show which switch staying open
Jul 16, 2008 at 11:37 PM
