2000 Ford Ranger crankshaft position sensor
160,000 MILES • 4 CYL • 2WD • AUTOMATIC
TOBISUKLINE
were is the crankshaft position sensor located on a 2000 ford ranger 2.5 liter and when it goes bad does it throw the timing off, and when installing the part does it have to be re timed somehow.
Dec 31, 2007 at 2:02 PM
BMRFIXIT
  • 19,053 POSTS
[quote:40660fb677="tobisukline"]Other Category problem
2000 Ford Ranger 4 cyl Two Wheel Drive Automatic 160000 miles
were is the crankshaft position sensor located on a 2000 ford ranger 2.5 liter and when it goes bad does it throw the timing off, and when installing the part does it have to be re timed somehow.[/quote:40660fb677]
crank shaft pulley
when it goes bad car wont start
no need for any adj after u replace it
Dec 31, 2007 at 2:07 PM
