2000 Ford Ranger Clutch Problem
30,000 MILES • 4 CYL • 2WD • MANUAL
HONDA2257
My brother has been driving my truck while down at school. he has only put on about 3k miles since going to school in aug. when i drov it everything was fine. now just about 2 weeks ago he came home and the clutch was spngy and hard to shift sometimes. so i bleed the hydrolic clutch. after that everything worked fine. Now he is back for Break and the clutch is doing the same thing back to spongy. I just went for a test drive put the truck in 2nd gear on dry pavement and started off slow. I hit the gas to see if the clutch would slip and there was no slipping. So I was wondering if its the Master Cylinder or the Slave Cylinder that would be the problem. Or even if the hoses. I just want somewhere to Start looking to solve the problem. Thanks
Mar 6, 2010 at 2:14 AM
KHLOW2008
  • 41,812 POSTS
Hi honda2257,
Thank you for the donation.
Start by checking the clutch fluid level.
If the fluid level is good, the highest possibility is the master cylinder leaking internally.
Look for leaks at the master cylinder push rod.
Mar 7, 2010 at 3:07 AM
