2000 Ford Ranger Clutch Noise
128,000 MILES • 6 CYL • 4WD • MANUAL
ENGINE343
When I engage and disengage my clutch it is making noise I think is the throw out bearing it doesn't miss going in gear but once I shift or disengage the clutch the noise stops, cannot hear it when I get on the road it is when I am backing up or leaving from a full stop.
Thank You
Hank
Apr 24, 2010 at 3:26 AM
  • 110,248 POSTS
Chances are it is the throw out bearing if you only hear it when the clutch is depressed.
May 12, 2010 at 12:51 AM
