2000 Ford Ranger clutch has no pressure
250,000 MILES • 6 CYL • 2WD • MANUAL
2000FORDRANGER
when i push the clutch nothing i checked the fluid and it was gone so i filled it up and i bleed the clutch but still nothing some air was coming out but i got it all and i checked for leaks and saw none so i dont know if there is one or not but what do you think i should do
Jan 26, 2009 at 10:07 AM
BMRFIXIT
  • 19,053 POSTS
Fluid out
you must have a leak in the system
most likely its the slave cylinder
check it out and if so the tranny need to be removed for it to be replaced
disconnect the line at the slave and pump the clutch until hard connect the line back and bleed the system
Jan 26, 2009 at 10:18 AM
