2000 Ford Ranger Clutch
121,200 MILES • 6 CYL • FWD • MANUAL
TOADIE1983
When I press on the clutch it is making a clanking sound as if something is caught up in the bottom of the truck. When you let off of the clutch it stops making the noise. And where is the Clutch resevior.
Mar 15, 2009 at 3:01 PM
  • 75,988 POSTS
Check the brake master cylinder and clutch slave if okay its probably coming from the clutch assemby-pilot bearing/clutch disc/pressure plate/release bearing
Mar 15, 2009 at 11:37 PM
