2000 Ford Ranger check engine light
99,000 MILES • 6 CYL • 4WD • MANUAL
PORKGRYND
check engine light came on after abs light came on after speedo died. only code on a snap on computer was for the abs speed sensor. replaced sensor, abs light is gone but engine light is still on and i no longer have access to the diagnostic computer. is there any way i can reset the check engine light?
Sep 8, 2008 at 10:06 AM
BMRFIXIT
  • 19,053 POSTS
disconnecting the battery will clear it all and reset PCM
light come back on u have a problem rescan for codes
Sep 8, 2008 at 10:30 AM
