changing my gear box oil
80,000 MILES • 6 CYL • 4WD • MANUAL
SAMSHASAI
how do i change my gear box oil?
Jul 29, 2010 at 11:46 AM
MERLIN2021
  • 17,250 POSTS
On the side of the transmission, find the drain plug, remove it and drain the fluid, install the plug, now find the fill plug halfway up the transmission case, remove it, fill with Mercon ATF until the level is even with the bottom of the fill hole. install plug. all done.
May 4, 2021 at 2:31 AM
