On the side of the transmission, find the drain plug, remove it and drain the fluid, install the plug, now find the fill plug halfway up the transmission case, remove it, fill with Mercon ATF until the level is even with the bottom of the fill hole. Install plug. All done.
SPONSORED LINKS
Tuesday, May 4th, 2021 AT 9:31 AM
