2000 Ford Ranger cannot put truck in gear
174,000 MILES • 6 CYL • 2WD • MANUAL
JAUBIN
My 2000 ford ranger will not go in gear. it was working fine and then as I started to shift it got harder to change gears and finally I stopped to make a turn and was unable to put the truck in gear. Could my clutch be gone? help
Feb 18, 2008 at 11:58 PM
MERLIN2021
  • 17,250 POSTS
First thing to check is the clutch master and slave cylinders, open the master and see if the brake fluid is full, not the brake master, the clutch master!
Feb 19, 2008 at 12:55 AM
