2000 Ford Ranger BAttery Replacement
75,000 MILES • 4 CYL • 2WD • MANUAL
EGRAMBERG
I just replaced the battery and when I turn the key I get lights etc, but when I crank it over it still clicks like the battery is bad, but it is brand new.
Jan 25, 2009 at 6:14 AM
DAVE H
  • 13,383 POSTS
check and clean all battery connection and wiring .. also ground points at chassis and engine block ... and hot wire from battery to starter motor !!
Jan 25, 2009 at 6:20 AM
