Removal & Installation (2.5L)
Disconnect negative battery cable. Remove drive belt from generator pulley. Disconnect generator electrical connectors. Remove 3 mounting bolts and generator from vehicle. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Removal & Installation (3.0L)
Disconnect negative battery cable. Disengage drive belt from generator pulley. Disconnect generator electrical connector. Remove generator wiring harness retainer. Remove 3 mounting bolts and generator from vehicle. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Removal & Installation (4.0L)
Disconnect negative battery cable. Remove air cleaner bolts and loosen clamp. Position air cleaner assembly to one side. Remove drive belt from generator pulley. Disconnect generator electrical connectors. Remove generator wiring harness retainer. Remove 3 mounting bolts and generator from vehicle. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Mar 6, 2009 at 4:10 AM
