2000 Ford Ranger alternator
ARTEMUS
  • 2000 FORD RANGER
Electrical problem
2000 Ford Ranger 4 cyl All Wheel Drive Manual
how to replace
Friday, March 6th, 2009 AT 11:59 AM
DAVE H
  • 13,384 POSTS
Removal & Installation (2.5L)
Disconnect negative battery cable. Remove drive belt from generator pulley. Disconnect generator electrical connectors. Remove 3 mounting bolts and generator from vehicle. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Removal & Installation (3.0L)
Disconnect negative battery cable. Disengage drive belt from generator pulley. Disconnect generator electrical connector. Remove generator wiring harness retainer. Remove 3 mounting bolts and generator from vehicle. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
Removal & Installation (4.0L)
Disconnect negative battery cable. Remove air cleaner bolts and loosen clamp. Position air cleaner assembly to one side. Remove drive belt from generator pulley. Disconnect generator electrical connectors. Remove generator wiring harness retainer. Remove 3 mounting bolts and generator from vehicle. To install, reverse removal procedure. Tighten fasteners to specification. See TORQUE SPECIFICATIONS .
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_10.png
Friday, March 6th, 2009 AT 12:10 PM
