2000 Ford Ranger abs
79,000 MILES • 6 CYL • 4WD • AUTOMATIC
DONNIE FLETCHER
took fuse out of my abs to disable them. regular brakes work fine. if abs is enabled a lot of weird things happen when the truck has almost come to a stop. the brakes seem to be working until the truck is almost stopped and then they release and the truck glides for a yard or two.
Nov 15, 2008 at 2:41 AM
DAVE H
  • 13,383 POSTS
LOSS OF SENSOR SIGNAL DURING VEHICLE DECELERATION OR SENSOR SIGNAL DROPS OUT AT LOW SPEED
Possible source of problem may be: faulty ABS sensor indicator, weak sensor output, or faulty air gap. Check front and rear ABS sensor indicators. Check ABS sensor mounting for debris or corrosion. See TEST D: ABS SENSOR OUTPUT FAILURE - DTCS C1233, C1234 & C1237 under DIAGNOSTIC TESTS
Nov 15, 2008 at 2:53 AM
