Engine Mechanical problem
2000 Ford Ranger Four Wheel Drive Automatic 85000 miles
can you tell me if a 1998 ford ranger motor will fir in a 2000 ford ranger flex fuel
Friday, January 8th, 2010 AT 2:17 PM
MECHANIC
I don't have the cross reference info. If the basic engine is the same size, it should fit, but you will most likely need to chance everything as far as sensor, vacuum hoses.
