2000 Ford Ranger
CAIRNSY
  • 2000 FORD RANGER
  • 6 CYL
  • 80,000 MILES
I have just had the wire harness changed and the truck cannot go into gear properly. It only goes to a low gear and doesnt shift up at all. It clunks into reverse.
Thanks very much
Wednesday, April 15th, 2009 AT 11:30 AM
BLACKOP555
  • 10,371 POSTS
What wiring harness? Does speedometer work?
Saturday, April 18th, 2009 AT 8:23 AM
CAIRNSY
The front wire harness, the speedometer does not work. Also wire harness and computer were changed
Saturday, April 18th, 2009 AT 11:35 AM
BLACKOP555
  • 10,371 POSTS
I would be checking over what you did make sure its all hooked up right and components near what you messed with wernt damaged.
Sounds to me like you have a bad vss or vehicle speed sensor.
Sunday, April 19th, 2009 AT 8:18 AM
