No.6 cyl is way too low-
a misfire in a specific cylinder should lead you to check the spark plug, fuel injector and compression.
Misfires can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
SPONSORED LINKS
Sunday, February 17th, 2008 AT 8:17 PM
